Morning Folks.
Heading might be misleading but here goes.
Specs first.
Ryzen 5 3600
32GB DDR4
NVIDIA 2080 Super
Aorus B550m Elite
Full custom loop
Front Barrow Distro Plate
Barrow CPU Block
Corsair Hydro X Series
2 x 240 Barrow Radiators ( Bottom Pull, Top Push)
Lian Li case O11D with side panel off
When I first watercooled the pc, the GPU would always get to 43 Degrees during gameplay, This eventually averaged to roughly 48 after a few months. Currently a few months after its now averaging around 50 degrees, with spiked going upto 52 degrees. I flushed out the system yesterday and added new coolant (De-ionised water) with mayhems inhibitor, but its again between
48 - 52 Degrees
this is at a 94% load,
Hot Spot is current 67.7 and
Memory Junciton is 66.8,
measured using argus monitor. Water temp never goes above 36. Ambient room temp is 20 degrees
Now the temps I believe are all fine, more than fine in some cases, but would there be any physical reason why the temps creeped up from 43 - 52 over a few months?
This is tested on the only performance game I play (Dont Laugh) Call of Duty Vanguard, Settings on Low at 2k 165hz
Specs first.
Ryzen 5 3600
32GB DDR4
NVIDIA 2080 Super
Aorus B550m Elite
Full custom loop
Barrow CPU Block
48 - 52 Degrees
