water cooling virgin
24 Mar 2004
kintyre
1 x XSPC Bay Reservoir - UV Blue
1 x 12V Laing DDC-1T Ultra w/XSPC Acrylic Pump Top
1 x D-TEK FuZion v2 CPU Block or 1 x EK-Supreme CPU - Plexi
1 x D-Tek FuZion GFX 2 Block
2 x Feser Tube 3/8" ID - 1/2" OD - Clear
10 x 1/4" BSPP - 1/2" Hose Tail Short (XSPC)
2 x Feser One Cooling Fluid - UV BLUE
1 x TFC Xchanger - Quad Radiator 480
4 x yate loon 2200 fans
cant decide on cpu block for a q6600 but how does the rest look to all you experts ?
All very good, although you won't need the clips if you purchase the 7/16" muskleer instead. When i put mine together i only used clips for the rad as i heard it can get a tad loose.
I'm not sure if the rad is necessary TBH - but then again, if you want to splash the cash then go ahead :)
What case are you using because to me, thats one of the most important parts.
Also, it might be worth checking out Cob's low £££ spec posted within one of the other WC threads floating around on the overclocking forum ATM.
last october i built my first computer and at the time it was a toss up between the silverstone tj07 and the tj09 ,i chose the tj09 because at the time i though i would never be interested in w/cooling :) but Ive decided to keep the 09 for now and just sit the radiator on my desk , i realise the rad may be overkill, decisions decisions, but i will maybe buy a 07 in future.
Will take a look at the Swiftech MCRES-Micro reservoir cob,thanks for the advice guys.
