Its been a few weeks since I finished building my new rig (see sig).
I am currently running my C2D 6600 @ 3.2 (355*9) on stock volts, the Tuniq Tower is keeping my temps at:
idle
Asus Probe 27-29c
Speed Fan: 27-29c
CoreTemp 40-42c
load
Asus Probe 43-45c
Speed Fan 43-45c
CoreTemp 53-55c
I am now thinking of Water Cooling, I have been looking around the forums with regards to the various setups available and as this will be my first WC setup I think I will go with a kit. My question is, which one???
I have seen three kits that take my fancy:
The Swiftech H20-220 Apex Ultra Watercooling Kit
the Asetek WaterChill Power
and the very sexy & expensive AquaComputer High End 240 Kit Aquastream with Cuplex XT Block.
Which one of the above will give me the best performance? Are there other kits I should be looking at?
I love the looks of the AquaComputer kit but as this if a low flow kit will it be able to better the temps of the Tuniq Tower by much?. Im not going for best Bang for Buck, I just want the best bang within £300. I only want to cool the CPU for now and the WC has to be considerably better than the Tuniq Tower 120.
idle
Asus Probe 27-29c
Speed Fan: 27-29c
CoreTemp 40-42c
load
Asus Probe 43-45c
Speed Fan 43-45c
CoreTemp 53-55c
