water cooling??
27 Oct 2006
I've never used it let alone tried to overclock my pc.
With graphics cards coming with water blocks I decided to buld a cheap test rig to see how it works and get to grips with the basics of overclocking, the problem is when it came to looking at watercooling kits I had no clue as to what to get .
the components for the test rig.
Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard.
Intel Pentium 4 541 "LGA775 Prescott" 3.2GHz (800FSB) with HT Technology.
Hiper HPU-4M580 Type R 580W ATX2.2 PSU.
Corsair 1GB DDR2 XMS2-5400C4 TwinX (2x512MB).
Sapphire ATI Radeon X1300 XT 512MB DDR2 AVIVO TV-Out/DVI (PCI-Express).
Akasa AK-ZEN-01-BK Zen Black Case .
I was looking at Asetek WaterChill High End CPU/VGA/Chipset Cooling Kit - 120mm Radiator/Fan
but I'm not sure if it would be compatible with what I was hoping to do ( was gonna see if I could put the vga waterblock on the sapphire x1300 if that's posible).
Any help or suggestions on different components for the rig would be most appreciated.
