Water cooling
14 Dec 2004
South
How much maintenance is there to do?
How often to flush, re fill etc...?
Trying to work out if I can be bothered, lol
Cool, cheers.
Well once I got a stable air overclock, cause ive only started to learn, I can get some water cooling and push it further. Plus ill have some time to save some pennies.
I was thinking CPU and GPU, not worried about the chipset. And tbh I cant remember if it has a fan or just a heat sink.
I just emptied a year old loop and the water was crystal clear with no additives so basically 0 maintenance (I emptied it to change components not maintain it lol)
Same here.
As long as it's clean water (I just use filtered tap water) and everything is sealed you should be able to minimise any maintenance to when you change something.
The newer fluids sound flash, but I'm not sure if they're necessary.
P
why spend all that when u can get an external waterkeg (custom made) by Newls on XS? it has all the top stuff and would only cost about 150 squid or so from the U.S.
Thats what id rather get, saves clogging up the inside of your case aswell.
Found the site and info on it. Looks cool, there some on the market like that, but his looks more basic, a better thing, thus cheaper and does a great job!
