water cooling
10 Jan 2009
London
i seriously don't understand water cooling and i need a setup for my system
basically just an antec 1200 case and an intel core i7 chip
need a water cooling spec badly i don't get all the different tube sizes and barb fitting ect and whats needed
i dont want a big rad! just a dual 120mm at the most i'm only cooling the cpu :)
but i know i would prefer a reservoir to a T line if thats ok to do, i also dont care if its a bay reservoir or built in with the pump i got loads room :D
Thanks
Are you sure watercooling is for you then? It's a lot of cash and effort and really there's not much point unless you're determined or desperate for that extra few mHz
well im not bothered about the cash, i saved 400 to buy a GTX 295, but realised my 4870x2 is good enough for me.
its purely for learning purposes, so i know what to do in the future if a client wants me to build a water cooled setup (luckily not yet :D), but also i would like to push my i7 a bit further see what more i can get out of it :)
Koolance BKT-HX001 rad mounting bracket £28.20
Koolance CPU-350 £52.02
Koolance HX-CU720H £34.47
XSPC Dual 750 Bay Reservoir £40.24
4 x Scythe Kaze Jyuni 500RPM Slipstream 120mm fans £32.16 (or higher depending on noise)
Tubing, Silver PVC £1.12per foot
3pairs of Nozzle Pair, G 1/4" Swivel Angled or Nozzle Pair, G 1/4" Compression £9.40 each
If you really want to push teh boat out and have a play
TMS-200 Software Thermal Interface Controller £62.68
2 x Coolant Temperature Sensor to measure in and out temps £21.30
INS-FM17 Coolant Flow Meter & Adapter Board £18.80
Assuming it fits in the case.
We can't email you competitors either. That's also against the no competitor rule.
I'm with Audigex on this, water cooling might not be a good call. How long have you spent researching it before asking for a spec on here? How long looking through the water cooled case gallery? I'd hope several days, but suspect rather less time.
