Why would you want to watercool a PSU?
And your sig is too big.
I wouldn't ever thinking of it since if you ever get a leak it's going to be very messy and would require custom blocks etc...
You can buy fanless server psus.
The fan on your psu should not be loud can you not rma it.
rma it?
Return manufacturer authorisation.
It basically means return it to where you bought it from.
Return merchandise authorization
