"Water deficiency heat generator 1" - Vaillant fault
26 Mar 2003
UK
Hi,
Just noticed "Water deficiency heat generator 1" on the heater control of our Vaillant thermostat. Can any one shed any light on possible meaning, causes and rectification of this?
Thanks in advance!!
Yep - know exactly whats wrong with it - I just googled "Water deficiency heat generator 1" on a Valiant :)
Ahhhh !! more info on original post would have helped. - :( Doesn't seem to be a DIY job
Thanks for the second post.
I just called a local plumber who suggested checking the pressure, it was indeed 0.7 bar, with the display suggesting it should be between 0.8 - 3.0. I've just re-pressurised the system to 1.3 idle (1.7 now the boiler has kicked in for the radiators etc) and the fault code has gone. The plumber suggested keeping an eye on it over the next 24 hrs but indicated that if this solves it then it will have saved me a £90 call out :)
