- 3 Jul 2006
- St. Neots
I have just set my watercooling up and already unhappy!
Slight routing problem and tube'd up the res wrong so decided to strip it down an redo it properly.
I am using Alpha Cool Tec-Protect UV blue water, but have noticed something I dont like!
All my tubes are now a slimey blue colour, after just 2 weeks! And the drained coolant is blur in colour, not clear like when it first went in!
I have bought 5 foot of tubing to re-tube if needs be but anyone recommend what to use, or why this has happened?
Cheers folks
Cheers folks
