- 5 Dec 2005
- Stockport
I am wanting to build a pc with a case with no fan holes in or anythin like that that is see through. I will then fill it with water. I was wondering how would i go about this, i think you have to use de iodised water but i am not sure, and i take it the PSU cant be in the case at all! has anyone done this as i would like some tips? Or even if you havent done it but know the theory your help would be great. Would i leave the fans in so they move the water around or would i leave them out cos they may break from pushing all that water?
) if you have a look on Toms Hardware they tried it recently and it would only stay on for 5 minutes. I think they ended up using mineral oil or something...
