hi all,
about to build my first water loop and need some help. im thinking of getting the following parts:
EK Supreme Clear Top CPU Water Block
EK LGA775 CPU Backing Plate
Alphacool NexXxoS Xtreme lll Rev2 Triple Radiator
Yate Loon D12SL-12 120mm x3
PrimoChill Anti-Kink Coils 3/4"
Masterkleer 7/16" Tubing - 1m
PrimoChill Dye Bomb - Blood Red
PrimoChill Liquid Utopia Protective Fluid
EK 1/2" Hose fitting x4
And....... the XSPC Dual 750 Bay Reservoir & Pump - Clear (if it's ever in stock lol)
Now comes the questions-
i’ve got 4 of the 1/2" fittings for rad and the cpu block. how does the reservoir connect to the loop?
1- Will i need another 2 1/2" fittings for the reservoir ?
2- And are the fittings going to fit on the rad that i’ve picked out?
