Hello All, I have a fully water-cooled rig (CPU, GPU1 and GPU2) i changed the water a little over a year ago but i have not flushed the loop in 3 years, i think it is about time i gave it some TLC to keep it running sweet.
Does Flushing actually work? i have used De-ion. water with some Clear Water additive, i did use Zerex but since it stained my last loop i changed it.
I have added some UV DYE but very little, just to give the water a TINT.
Thanks all.
PS, if this is recommended, what solutions should i be looking at?
Thanks all.
