Water loop - where to put these rads???
13 Feb 2008
Glasgow
I have two radiators - one Swiftech 220 and one XSPC 120. Pump/cpu block is Swiftech drive. GTX280 block is Aquagrafx G200.
Question: How should I configure this loop?:
1) Pump/CPU block -> GTX280 block -> 220 rad -> 120rad -> Pump/CPU block
or
2) 1) Pump/CPU block -> 120rad -> GTX280 block -> 220 rad -> Pump/CPU block
Won't really matter (temperature wise), it's not a complicated loop, go with what's easier to route inside your case (imo). If you have a res, make sure that's before your pump.
Thanks. In this case a lot easier will be: CPU/pump-GPU-220-120-Tline-CPU/pump.
I use T line just before pump.
Good luck, get a picture up on the forum when you've installed your loop!
No problem:)
Now I can only show how it would look like.
Thats the cube (not finised of course, if you want to see all, go to my worklog):
Here's the sketchup how it will be built:
