- 1 Mar 2010
Hello everyone,
I am writing here because I found a very similar thread back in 2017.
The water company carried out major works in my small street of 13 houses, replaced the water main, I am not sure what with. They dug up to my water meter and I presume replaced the mains pipe right up to it.
From the water meter there is an underground, 40+ year old water pipe, black, seems to be around 20mm OD and perhaps 15mm (or less) ID. It runs for about 40 meters before entering the house.
I have just measured around 2.6-2.8 bar static pressure and around 15lt/min flowrate. With the tap fully open the water pressure collapses, almost to 0. In practice, if I flush the toilet, there is a trickle coming out of the water tap in the bathroom. Or if someone is having a shower there is very, very little water at the kitchen tap.
We are digging a trench to install a new electricity and gas lines, and at the same time I'd like to replace the old mains water pipe as well.
What size should I go for, and is it likely to make a difference? Choices are 25mm, 32mm, 50mm, 63mm, 90mm. The 32mm is 26mm ID, the 50mm is 40.8mm ID, the 25mm is 20.4mm ID and finally the 20mm is 15mm ID. There are differences in price especially as I might just need over 50m, otherwise I think I'd use a large size eg 50mm.
Any comments welcome.
