Water Temperature Controlled Fans
21 Jul 2017
I'm wondering, what's the easiest way to control my radiator fans by my water temperature? My fans speed up, then slow down, quite quickly whilst playing games and such.
What mainboard you using ?
Asus suite software has a Delay you can adjust than means the fans take a longer period before adjusting speed etc, it helps even out the noise
The more expenstive option and what i have done is use a Aquacomputer Aquaero 6:
https://www.overclockers.co.uk/aqua...uaero-6-pro-usb-fan-controller-bb-001-aq.html
Then attach a water probe:
https://www.overclockers.co.uk/aqua-computer-temperature-sensor-g1-4-wc-119-aq.html
Run fans back to Aquaero, bit of fliddering and sorted :)
