Water Temps?
1 Dec 2011
Hi guys,
What sort of water temps do you get?
With 2x very overclocked 7950s and a single 360 I am getting water temps in the low 40s, which results in GPU temps in the low 50s.
Seems a bit hot to me, perhaps a second rad is in order.
Anyone care to suggest what sort of water temp i may get if I add a square 200mm rad to the loop?
Also is a dangerous water temp? Are leaks more likely above a certain temp, etc.
Thanks in advance.
Oh right, thanks.
I thought the aim was for a delta of 10 degrees? My delta is about 20. Is this the sort of figure you guys are getting?
Lower temps than me. I'm getting around a delta 25c give or take when my 2x7970 & 3770k...with a 60mm 240+360. My fans run 600rpm and ramp to 900rpm though.
I'm sure my temps would be lower if i could bare the noise though lol. Went on a tangent, but your temps are good.
Ok thanks guys, perhaps that 10 degree delta was from an old article relating to cooler hardware.
On a seperate note - seriously, if someone asks if they should buy more PC parts, surely the answer is always YES.
