- 29 Nov 2005
- Milton Keynes
I have just bought the Swiftech H2O 120 Compact Kit.
I fitted my hoses to it, marked them for size, then removed and cut. When I put them back on, I realised I had put them on the wrong way round!!
When I attempted to remove the hose from the output connector it broke off. I have been advised this would be put down to my fault, so a warranty replacement would be out of the question. So now I need a new CPU block and more tubing.
I am looking at the D-Tek Fusion CPU block:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-000-DT&groupid=701&catid=193&subcat=1034
As this has 3/8" barbs, but all the tubing on this site is marked as 8mm. Is this the same as 3/8" or not?
Is this waterblock a good one to choose?
I have £900 pounds worth of PC sitting here and I can't use it because I bought an OEM CPU, so have no cooling for it. This is for an Intel Q6600 processor.
