i dont understand, can you explain the problem a bit better
Tubes kinking is bad news it'll ruin your flow rates, get some anti kink braid on there asapi'd also replace the tube too
Not surprised, that tube shouldnt be going into the top like that, there is an air trap at the top of the res causing the problem. The entire loop should be sealed by water ideally.
If the res came with a solid length of tube which inserts into the top inlet like this http://www.overclockers.co.uk/showproduct.php?prodid=WC-089-EK&groupid=962&catid=1551&subcat= then you are OK. Although I would still make sure you have fully bleed the loop by at least laying the case on its side, as bleeding a top rad with the barbs pointing downwards usually requires this in almost all circumstances.
That tube goes in the res from the top fitting and hangs down part way into the res and basically below the water lvl, this means that any air still in the system will eventually get pumped down that tube into the res and float up into the top of the res.
Edit: Bad drawing but it gives u the basic idea.
