5 Jul 2010 at 14:21 #1 waso_dude waso_dude Soldato Joined 22 Oct 2006 Posts 5,913 How are the EK blocks comparing to the Heatkillers now? With the HK at nearly half the price is there much in it?
5 Jul 2010 at 14:31 #2 NathWraith NathWraith Soldato Joined 11 Dec 2005 Posts 11,363 Location Cheshire depends which block your looking at. The CPU blocks are fairly similar, same can't be said for the GPU blocks however.
5 Jul 2010 at 14:33 #3 Dimi Dimi Associate Joined 10 Sep 2008 Posts 1,662 Location London http://www.skinneelabs.com/cpu-blocks.html The EK Supreme HF is the better block, not by much though.
5 Jul 2010 at 15:21 #4 waso_dude waso_dude Soldato OP Joined 22 Oct 2006 Posts 5,913 NathWraith said: depends which block your looking at. The CPU blocks are fairly similar, same can't be said for the GPU blocks however. Click to expand... Well i'll be getting another EK block for a 5850. My 8800gt one has been amazing.
5 Jul 2010 at 16:01 #5 Ordokai Ordokai Associate Joined 16 Apr 2010 Posts 411 Location Nottingham ------------------------------------ Temperature difference CPU-Water [K] ------------------------------------------------------- Lower is better. As you can see the performance is, for all intents and purposes, identical. The full article can be readily found here - Ordokai Last edited: 5 Jul 2010
