Evening all!
Bought some Phobya Dual 3MM LED LEDs. Basically 1 x molex into 2 seperately cabled LEDs.
For some reason only one of the LEDs works on each set. I have taken power from a single molex, split it into 2 (Y cable) and then connected both Dual LED Modules to the now available 2 molex connections.
I find it hard to believe that BOTH have a faulty LED/Wiring on, but it's possible. The single working LED on one of the modules also turns off for a while, then comes back on.
So intermittentcy + never working LED on one module and only one working LED on the other. Before I start ripping them out and testing them, is there anything quirky about wiring up LED modules I should know about?
As far as I am aware Y splitting a Molex plug will still provide the necessary Voltage to each component on that chain.
