waterblock for gtx 770
I dont think there has been any announced yet, You will have to wait a bit sorry.
I think the 770 gpu core is smaller than Titan but the pcb is similar. I dunno if nvidia is cutting costs by re using the same pcb and layout for their gpu. I would wait for confirmation of fitment first.
YES!!
The 770 Lightning uses the GTX680 Lightning PCB, you CAN use the 680 LTG waterblocks with the 770 LTG!!
The reference 770 requires a new waterblock to be made, BUT it shouldn't take long as the PCB is very similar to that of the Titan/780 to the point the 770 blocks will take Titan backplates...I suspect its just a rogue cap or two stopping Titan blocks fitting.
