I have had a Custom water cooled system for 5 and half years with overclocks, the cpu was 5820k,and 980ti s and recently one of the tubes disconnected and leaked all coolant, and shut down
Fortunately most of liquid leaked under case on to floor
I recently found out the motherboard is at fault since most likely from the leak or power issue
Not sure if rest of components are still fine as it was gpu and cpu cooled
Last thing I was doing was playing a high demand game
Has anyone else had issues of this failure and possible causes
ps it’s not been moved often but was on a floor under a table
