Waterchill kit
23 Nov 2004
UK
Anyone know the size of the Barbs on these kits?The 1 i have has dodgy push fit connectors! Can these be changed as i have bought some DD 1/2" Tube and would like to use that instead of the 10mm straw they supply for pipe.! This kit uses the Hydor L20 Pump.
Not easy to use ½" ID with the Waterchill stuff. You'd probably have to change all the quick-fit fittings to standard ½" OD barbs. I don't know the thread sizes of the existing fittings or even if they can be removed. Sorry.
