Well I have bought all of my parts now. I am just waiting for the PA120.3 to come back in stock
1 x Zalman ZM-MFC1 Plus Black
2 x Feser One - F1 - Cooling Fluid - UV BLUE 1ltr
6 x YATE LOON 120mm - D12SM-12
10 x Masterkleer 7/16" ID 5/8" OD PVC Tubing
1 x Rad Brackets - External Radiator Mounting
1 x Watercool HeatKiller CPU LGA1366 Rev. 3.0 LT
1 x PrimoChill Anti-Kink Coils - 5/8" OD Tubing - UV Blue
1 x Laing DDC 18w Pump / Swiftech MCP355
- Aftermarket Top: XSPC DDC Top With RESERVOIR
- Barb Size for Selected Top: 1/2"
2 x DTEK G1/4" Hi-Flow 1/2" Barb
1 x 12-20mm Hoseclips Pack of 10
1 x Arctic Silver Arctic CERAMIQUE - 2.5g
and some additional cables to help with cable management round the back.
Akasa 20/24-Pin 30cm PSU Extension Cable £3.99 x1
Akasa 8-Pin 30cm PSU Extension Cable £2.99 1x
Akasa AK-H254 60CM 3-Pin Fan Extension Cable x6
I cant wait to start putting it together
