Hello, so I want to watercool my CPU and maybe my GPU if my low budget is good enough.
My specs:
i5 2500k
Casecom KM-9188 - it's cheap I know... But it has pre cut holes for watercooling
Radeon HD 6870
Asrock p67 performance edition motherboard.
I don't think you need anymore information for specs, tell me if you do...
The budget is £140, may be able to push a tiny bit more.
Thank you..
Best regards
kbkasey.
My specs:
i5 2500k
Radeon HD 6870
Thank you..
Best regards
kbkasey.
