Thanks for looking and your assistance in advance!
Looking at watercooling my system again as my gets 3090 is crazy hot in my little office. This is what i'm looking at. I've WC before but about 5 years so assuming most things are still the same.
With hard tubing, is it worth it? difficult to bent or can i just use 90degree connectors to make it easy?
I already have the case listed below (lian li lancool2), so can fit the 240 and 360 and thinking the distro panel for the rear.
Just need to sort fittings and piping i think? any changes, missing i would need?
My basket at Overclockers UK:
- 1 x EK Water Blocks EK-Quantum Vector ASUS TUF RTX 3080/3090 D-RGB Water Block - Nickel + Acetal= £159.95
- 1 x EK Water Blocks EK-Quantum Vector ASUS TUF RTX 3080/3090 D-RGB Backplate - Black= £39.95
- 1 x EK Water Blocks EK-Quantum Inertia D5 PWM D-RGB Pump - Acetal= £129.95
- 1 x Phanteks Glacier D140 Distribution Plate with DRGB Lighting= £89.99
- 1 x EK Water Blocks EK-CoolStream SE 240 (Slim Dual Fan) Radiator= £48.95
- 1 x EK Water Blocks EK-CoolStream PE 360 (Triple Fan) Radiator= £77.99
- 1 x Monsoon Premium G 1 / 4 Temp Plug - Matte Black= £4.99
- 1 x EK Water Blocks EK-RES X3 150 Lite= £44.99
- 1 x EK Water Blocks EK-RES X3 250 RGB Tube Reservoir - 250ml= £64.99
- 1 x Lian-li LancooII II mesh front panle kit, Black= £34.99
Total: £696.74 (includes shipping: £0.00)
