I'm pondering my next GPU change and had held out for the 480 to appear before making up my mind. Now it's getting a bunch of bad press, but, it does seem to for most purpose be the quickest single GPU solution at the moment.
I could go 5970 or dual 5850s I suppose but by preference I'd rather avoid multi GPU solutions and ATI drivers of late don't fill me with confidence. There's no doubt though that the 5970 is a stocking, albeit slightly more expensive solution however...
It'll be watercooled which should take care of the heat and noise problems whatever I go for so perhaps I should consider the 480 after all. I'd almost certainly add an EK block myself but the EVGA watercooled 480 suggest temps of ~50deg and a moderate overclock out of the box.
Any thoughts on the merits or not taking into account the W/C option without degenerating into a flame fest chaps?
I'm going on expert reviews on the web who claim the card runs dangerously hot and will not be good for the longevity of the card, in turn watercooling would be the best option, in fact I believe it to be a necessity if you have the funds, and of course no hoover style fan going off when the card hits 90c+ temps.
