watercooled 540
2 Aug 2010
Egypt/ Surrey
I have recently changed cases from my tj08.
My specs:
2600k @4.8
Windforce 780 OC rev2
8gb xms3
GENE V
H80
AX 850 psu
TJ08
Custom braided mdpc cables red, black and shade 19
give me a shout if I need to resize- I am using my phone to upload :/
My new spec has most of the above. The wf780 has changed for a 780 lightning in addition to the
the watercooling gear. The case is a corsair air 540.
EkPE 360
EK XT 240
6 x QE SP120s
ek compressions
2x xspc compressions
a few g1/4 extenders
ek 3.2pwm ddc pump/ tube res combo
Mayhems blood red pastel
black shoggy sandwich
I began by stripping the case and removing the H80 backplate from the motherboard. Once this was completed I installed the CPU block and the motherboard into the case.
I then began installing the top rad. I knew the ports would need to be on the left side in order to access the pump which is resting on the SSD cage in the rear of the case.
*I realised very early that I did not have appropriate screws in my tool box to fix 2 fans the to 240 rad. I needed M3 x30mm and I had M3 x 25mm :/
So you'll notice no fans on the top rad for the first few pics.
By this point Ian the DPD man arrived and left me with my PE360, tubing, 2 bottles of Mayhems and 2x Haribo...nom nom.
I then began to add the fittings, 360, pump/ res and fans. The rear fan is intake and the rads are exhausts I will see how they are for now I may swap it about in the future.
I had bought some bitspower fittings to use in the build, however I couldn't find them so had to settle for some ek. I had to use 2 xspc fittings as I didn't have enough ek fittings so I put the 2 xspc fittings on the pump in the rear of the case.
The next part of the build involved adding tubing to all fittings which was easy enough- my hands still hurt- but it is done.
I then began to leak test... this was where the problem began.
in the rear of the case my res began to leak from the input fitting. I tightened it, changed it and then added a second o ring and extender before adding the 90 degree fitting.
once this was fitted correctly I then refilled and leak tested for about 6 hours prior to letting the pump run. I then began to bleed and all of the bubbles seem more or less out already. The shoggy sandwich seems to be doing a grand job, despite just using the harder foam double layered and then the soft foam to stop the case hitting the pump. The vibrations are well and truly dampened. I cannot feel the case moving.
So now I am just finishing off the rig with a fan controller which will be kept internal along with another pcie cable from davido :)
my small order tomorrow contains a fan controller, pwm fan extender cable, i.o. panel cables in red x3 and a demicflex 120 filter for the rear intake and a silverstone filter for the underside to try to keep dust down and out.
I have found the corsair air 540 a great air cooling case with lots of room to sort things out. I found my wc gear to be pushing the case to its limits. I was lucky that the GPU just managed to fit with the fans in push on the 360 rad. I could fit another 780 in but again it would be tight to work.
see how close...
Stunning mate - cant go wrong with red and black scheme ;)
Thanks
I always wanted red and black when I had my original p55 system but eventually got my wish :)
I am hoping to sort a 780 lightning backplate from Coldzero as well.
I have now added a Lamptron touch which is controlling all fans. The pwm wore for the pump is attached to CPU header.
I have also added a demicflex 120 filter at the rear intake and bought a large filter for the underside of the case. I still want to block off the lower HDD drive bays as they are fugly.
To fit the lower filter I had to turn the case upside down which meant I had to reveled, apparently a little air was stuck in the system in the top rad. But I think I have the last of it out.
Idle temps in the morning are 21 or so degrees highest I've seen in the day so far after a few hours gaming is 51. With CPU at 4.8ghz and GPU only very slightly clocked
Have you blocked of the holes in the bottom to stop dust coming in?
Currently using this on the underside.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-027-SV&groupid=701&catid=2331&subcat=795
I hope to fully block it off at some point. Perhaps with a custom job by Ricardo using a modified midplate or something similar
but for now I have removed the filter and attached it directly to the case. Better option might be to use magnets in future but for now I have used glue
