Further to my previous thread here http://forums.overclockers.co.uk/showthread.php?t=18209240 about temp problems with the H50 I decided to go with a full on water-cooling set up. I've just powered up for the first time and the first time around it didn't stay on long before powering down, I think it hit it's thermal cutoff. It then reset it's bios settings and booted again and stayed going.
I'm in windows now and the temps at idle are 64, 60, 61, 62 which is higher than they were before and the pwm fan on the motherboard cpu header is going like the clappers. Thing is the CPU block doesn't feel hot. I've just got a single loop which goes:
XSPC reservoir with Liang D5 pump > XSPC RX420 dual radiator (mounted at top of case) > Heatkiller V3 > back to reservoir.
From what I read before I ordered my stuff this seemed plenty to cool just my CPU. Not sure what to do next, help!
