Yeh, although the cooling is not any better than high ish end air, and its no where near as good a case as a Lian Li, and the cooling is no where near as good as a proper solution.
Buzz me on MSN, ill send you some PDF's on the cooling of the tai chi.
I have the thermaltake Bigwater cooling and I get 29*C with a silent fan on the rad, and the room temperature is 27, so I am quite pleased with its performance.
But... It isn't worth getting a case with watercooling already set up, I would go for a case you like and a custom watercooling kit from a dedicated cooling shop (to get full choice.)
