- 16 May 2011
- Staffordshire
Hi, i'm in the process of building a custom case as part of a year 13 extended project. I was always planning on watercooling the build for aesthetic as well as functional purposes but now i'm thinking making it partly passive.
This is the original sketchup design:
And this is the progress up to now:
I designed all the CAD files using NX uni-graphics and all parts were very kindly laser cut bend welded and finished by KMF in Newcastle (nextdoor to Overclockers)
The rest of the work is up to me now...
So on to the point....
Two 240mm radiators will be positioned her as below. Air will flow straight through from one side to the other.
As i am quite pedantic about a lot of things, especially noise, i want the system a quiet as possible. The watercooling should ensure this when the system is in use for gaming but a lot of the time, the system is left almost idle downloading things or when streaming media. So i was planning on being able to make the system completely passive for some of the time. My plan to do this was to position a custom made passive radiator on the outside rear of the case where a plain cover would have gone.
The radiator would be made something like this:
This is certainly not to any kind of scale and i think the fin density here is wayy to high for passive.
The fluid would always flow through here first whether passive or not.
I need to think about what material to make it out of. I would just go straight for aluminium but i think i would likely have a problem with galvanic corrosion so copper is the alternative despite the cost. Brass may be an option however it is much less thermally conductive.
I will make it using a CNC mill so that is not an issue.
What do you think of this idea?
How effective would it be at dissipating the heat or is this likely to be a test it and see job?
