- 28 Oct 2005
- Stoke-on-Trent
Ok just finished off my install.
cooling
Apogee GT
Thermochill 120.1 Rad + Panaflo 120x38
Swiftech Micro Res
Swiftech MC655 Pump
7/16 Tubing
Zerex and Deironized Water
2x 120x38 Panaflo Fans
Specs
Core2duo 6600
PW5B DH
G.SKILL 6400 HZ
X1800XT (till r600)
Corsair HX620 PSU
Decided to go with a single 120 rad over double because i was only cooling the cpu and wanted to install it all internal without the loss of drive bays and also didnt want something hanging from the back. I had already cut a top blowhole a while ago. The only other thing need to be cut in order for the rad to fit was the psu tray.
At the moment i am getting 48c load with dual prime on 3.6ghz 1.45vcore, temps taken via TAT. This is will the fan on lowest setting and pump on medium. Before on air, this was creeping up to 70c.
This sound right?
Ok here are some pics -
cooling
Apogee GT
Swiftech Micro Res
Swiftech MC655 Pump
7/16 Tubing
Specs
Core2duo 6600
PW5B DH
G.SKILL 6400 HZ
X1800XT (till r600)
Corsair HX620 PSU
This sound right?
Post your rig in Akasa Eclipse club thread... well done M8
