UPDATE IN 5th POST
Hi guys, havn't posted much in this forum, but I thought that since the build section was new, I would give it a try.
So I had been running a FT03 black case on air since january. It was used mostly for a HTPC, with some gaming as well (I had a HD 6850 GPU back then), and running some matlab/fortran simulations. It was pretty quiet, with a DARK rock pro and be quiet 120mm fans... but it wasn't quiet enough (and I also wanted to try watercooling
The parts back then were:
Asus GENE-Z gen 3
i5 2500K
vertex 3 120gb
2x 2TB samsung F4
Seasonic X660
Random ram 16Gb
asus HD 6850
slot load Bluray drive
Blackgold BGT3620
Unfortunatly I only have a pic of the components in the case when I had an am3 mobo with Athlon X2 and HD4850 (burnt because of short) and seasonic M12, so here you go so you can see the size of the dark rock pro
IMG_0077 par Chluz, sur Flickr
My brother wanted to do watercooling on a FT02, but he was too slow making his mind up, so I decided to get some practice on my own system.
I decided that I needed a big radiator, I didn't want any of the 160 rads underneath the GPU, or a small 120 at the top. So I went for a phbya Xtreme 200. The surface area is superior to all other alternatives I had seen out there for this case, but the air pressure for 230mm fans isn't so great. I though i'd try anyways.
For the rest of the watercooling, I used massive Tygon 1/2ID 3/4OD clear tubes, blood run premixed fluid (I know I know, don't use premix, use coloured tubes, but to be fair the non UV reactive premixed shouldn't clog up that much), cheap black niquel fittings, an EK 2.2 waterblock and pump, a EK supreme full nickel and a new 6950 with a copper block I got used (unlocked to 6970 of course
And so I started with my first iteration fo watercooling
Front view
_MG_5696.jpg par Chluz, sur Flickr
and the top.. with a radiator balanced on a ruler and a 9V battery, and a box lid
_MG_5698.jpg par Chluz, sur Flickr
But I had a plan for the top radiator. I wated to use a new 3D printer I had available to me to build a custom made fan and radiator chassis to fit on the top. Here are some pics:
angled view
Sans titre-1 par Chluz, sur Flickr
top
top par Chluz, sur Flickr
Side
front par Chluz, sur Flickr
That chassis would sit on top of the panels, just like the previous plastic lid did.
Here are pics with the new chassis on
_MG_5811.jpg par Chluz, sur Flickr
top view, missing a mesh panel that will sit in built in grooves on the side
_MG_5813.jpg par Chluz, sur Flickr
Side view
_MG_5808.jpg par Chluz, sur Flickr
Of course I needed to be able to remove that lid to connect new stuff on the motherboard; to do this i added quick disconnects routed right behind the front manel of the case (where the cd slit is).
_MG_5814.jpg par Chluz, sur Flickr
disconnect the quick disconnects
_MG_5816.jpg par Chluz, sur Flickr
and then just lift off the top
_MG_5818.jpg par Chluz, sur Flickr
Next iteration of the project will modify the tubing connecting to the quick disconnects and add a drain line, as I don't think it's very neat. I also don't like the pump tilting forward that much, proabbly because the foam underneath is abit too pliable, and the tubing is a bit heavy... oh well. Tell me what you guys think.
Asus GENE-Z gen 3
i5 2500K
vertex 3 120gb
2x 2TB samsung F4
Seasonic X660
Random ram 16Gb
asus HD 6850
Blackgold BGT3620
Front view
angled view
top
Side
Side view
