Watercooled Haf X
18 Oct 2002
Liverpool
Almost have my new build finished and wanted to share a sneak peak to get some advice and comments before i finish it off with decent pics and to show more of it
Mostly EK kit as i got a bargin on a complete kit, added the EK GPU blocks the EK rad is mounted on the top and the rad on the back is a Black Ice SR1(Greboth might recognise it :) )
On my to do list
Get some nice braid for the graphics and motherboard power cables, pump cable, and some other misc bits
replace the HDD and power LED's for some blue ones
replace the LED's in the front fan to be blue
most likely get some 45 degree barbs, one from the graphics card to res and to work out a route to reduce the tubing for the external rad
Looks good m8 the braid you on about are you getting the pre-braided extensions if so go for bitfenix ones they are really good.
i think to save my sanity the GPU and Motherboard will be pre-braided but might have a go at it myself for all the fan and pump cables etc
and ty for your comment :)
