Watercooled P180/P182's...
tsj
tsj
Permabanned
7 May 2004
United Kingdom
If you've got a P180/P182 watercooled... can you post some pics of your setups... I'm looking to see how you guys have got yours setup so that it will makes things easier for me when I decide to switch over :)
I've just put some watercooling in a P182 SE
I've got 3 PA120.1's in there, 1 on top, 1 on the back and one on its side in the top drive tray bay.
What's that you've got there then?
Also ... any chance of some better pics?
Thanks
Here's a couple of my P182 setup.
I wanted my kit to be all internal, partly for looks, but mainly because I'm really pushed for space and having a rad hanging off the back or the top isn't really possible.
I've got 2 x 120.1 rads (an XSPC crossflow and a waterchill jobbie from an old kit), with 2 x Yate Loon 120mm fans in a push/pull config on each rad.
I plan to install a Thermochill PA 120.2 in the roof space (still internal) but this will mean cutting a hole in the top panel so I'm going to do that when I next have to strip the components out for a dust etc.
I've got the CPU and Northbridge cooled at the moment.
