Right 1st of all this is my 1st setup so I apologise for any stupid mistakes I've made.
Basically the q6600 (B3) when watercooled maxes at about 65-66 degrees under load at stock frequencies. When i had the tuniq tower is was about 54 - 56 at load. The cpu is lapped and I'm sure I've applied the AS5 correctly.
My setup is basically the swiftech ultima 220 with an additional 120mm radiator, the EK waterblock for the 4870 x2 and the feser red UV fluid. The circuit is: pump>240mm radiator>cpu>120mm radiator>GPU>reservoir.
The 240 mm radiator is on the outside of the case with 2 fans. I've cut the side window to attach the 120mm radiator with the 120 mm radiator on the inside of the case. The case is just a zalman gt-1000 which I've just drilled a few holes into.
The 4870 x2 is about 30 at idle and doesn't go over 54 degress no matter how much I overclock the cpu.
So are there any simple ways to lower these temps? Anything I haven't thought of? I replaced the feser one solution with distilled water and the green stuff given with the 220 ultima which lowered temps about 2-3 degrees. Anything else?
