yeh i have to agree its probably not going to do the tmps any good which is why people watercool in the first place, maybe look at having 2 loops, 1 for gfx and 1 for cpu
yeh thats probably the best bet , maybe buy a 120.2 for the cpu ?
iirc, there are 3 holes for rad fans? have a 120.1 for cpu and 120.2 for gfx cards. no neec to discard the caseoriginaly started out with a banchetto 101 bench table but now with going to do this im going to have to go back to my mountain mods case. pitty only had the bench table 5 weeks.![]()
but as others have pointed out, he'll need to have 2 loops, hence 2 rads, and seeing as there are 3 fan spaces, he can fit a 120.1 and a 120.2 in therei think the op allready has a 120.3![]()
but as others have pointed out, he'll need to have 2 loops, hence 2 rads, and seeing as there are 3 fan spaces, he can fit a 120.1 and a 120.2 in there![]()
on your desk? make some kind of pump enclosure, sounds boring, but may workjust a very tight fit putting another pump in there. ill have a sit down and a proper good look into this. but if i can fit them in it would be brilliant.
