Watercooled Temps
28 Oct 2005
Stoke-on-Trent
Ok just finished off my install.
cooling
Apogee GT
Thermochill 120.1 Rad + Panaflo 120x38
Swiftech Micro Res
Swiftech MC655 Pump
7/16 Tubing
Zerex and Deironized Water
2x 120x38 Panaflo Fans
Specs
Core2duo 6600
PW5B DH
G.SKILL 6400 HZ
X1800XT (till r600)
Corsair HX620 PSU
At the moment i am getting 48c load with dual prime on 3.6ghz 1.45vcore, temps taken via TAT. This is will the fan on lowest setting and pump on medium. Before on air, this was creeping up to 70c.
Does this sound ok? bearing in mind i am using 120.1 rad
footman said:
I think those temps are really good. ATM Ive got orthos running blend and I have temps of 52 @ 1.38 vcore.
Thanx. Long as they are below 60 i'm happy. On air is was hitting 70c on the same vcore :eek: Are you just cooling your cpu or graphics card too?
Those temps look good... I'm getting around 45C load max with a 6400 @ 3.4GHz using 1.38v and a X1900XT on the loop. Before watercooling my 6400 was going well above 60C!
w3bbo said:
Those temps are good for a 120.1, especially considering you have a gpu in the loop!
he only has cpu in the loop, but yeah nice temps. Footman has gpu in loop though if thats who your talking about
