Watercooling 4870?
I'm using a Maze4 and it's doing a wonderful job :) very nice low restriction block
^not too bad but they are aluminum so I wouldn't advise putting them in a loop unless you are using an aluminum cpu block and aluminum radiator...
Meh.. new there was a catch :P
Gurusan what do you run your Q6600 at when your not benching?
i just got it yesterday so I have not hit the max yet, but i'm running it at 3.7ghz now.
just had a disaster...was attempting to install XP and my cd drive messed up because I kicked it on accident :/ it froze mid-install and somehow the MBR was screwed up.
No worries I said, and reformatted that partition, then on reboot I see a bunch of partitions with 0mb on them and I can't do anything with them! Ended up having to reformat the entire drive...lost a few things of sentimental value :(
My next purchase is going to be a dedicated OS drive so this never happens again. Perhaps a raptor :)
