Right
Got hold of some watercooling goodies as follows
Swiftech MCP655 pump
Alphacool Cape Coolplex Pro 25 Reservoir
Swiftech Apogee GT Waterblock
Swiftech MCR220-QP rad
They are all 2nd hand so i have clean the cpu block and lapped it for a nice clean new finish.
going to get radiator cleaned out with some de-inonised water and vinegar.
Same for reservior.
My questions are as follows:
Do you need/should you have a fan controller for the speed of the fans on the radiator? What fans should i get?
Should i use Feser or just stick to Distilled water and deionized water??
Masterkleer 7/16" Tubing - seems to be flavor of the month - anything else to consider?
Worried a little about the cpu block and having read about mixing metals etc?
Will a dual rad be ok if i decide to water cool my 8800gt at some point in the future? If i do what block should i consider?
Same for reservior.
