Watercooling a P160?
3 May 2004
Hi,
Has anyone attempted to fit watercooling to a P160 case?
Anyone think it has enough space for the task?
I would really like to avoid hacking my case apart for tubeing and such so having some sort of pass-through pci bracket would be nice.
Im currently looking at the Swiftech Apex Ultra+ kit and the Reserator 2 for the possible choices.
Idealy I want to go watercooling for the added silence and more overclocking headroom to help my system last longer as I wont be upgrading it for at least another 6 months to a year.
Thanks for any help.
Fits no problem mate,i would go for the swiftech if i were you.Here is my old set up in a P160,cooling an X2 & a 1900XT.You could fit a 120.2 in the top,but i drilled a couple of holes in the rear for tubing as my rad sat outside the case
I've used a pci pass through bracket before on a swiftech set up,if you need any more pics or info,drop me a mail & i'll sort you out ;)
[/URL][/IMG]
