watercooling a psu
10 Dec 2012
leicester
hi their i was wondering it would be possible to watercool a psu.i know water and electrics dont mix but it would be a lot quieter and more efficent
Seems pointless since you would have to cool the total wattage of the psu & the components, if you want true silence buy a passive PSU.
Maybe just try putting a resistor on the fan, or even replacing the fan with a quieter one if its standard size, then just keep checking its not overheating.
I imagine watercooling a standard psu would be difficult, cause even if you could make a water block to replace the big heatsyncs in there, im sure theres probebly lots of little parts that are normally cooled by the fan, even if they dont have heatsyncs.
Can't even hear the fan on my near 5 year old HX1000. Should probably check its actually working :D
If it was viable to do then kits would be available, all I've seen is a relatively shoddy looking 1000w unit from koolance, which costs more then an AX1200i and performs worse (bronze vs platinum).
I personally think just a really good efficient PSU is ample enough, gold or platinum in some sort of silent branding :)
Of course it's possible. Just not sensible. Don't cool a live heatsink, i.e. if a multimeter reads mains ac, don't cool that bit.
Running a 5 year old 850W Cooler Master PSU here, still as quiet now as when it was new. Totally inaudible.
The PSU is fine, though it no longer has a waterblock inside (corrosion problems). There's a 1" hole cut through the steel casing, which is ugly, but appears to make no difference. Voltage still within spec (based on multimeter, not oscilloscope) under load.
I wouldn't recommend repeating the attempt, but it doesn't seem to have caused any damage.
