Hello all,
I'm currently about to get my next WC kit in the next few days, and basically need some advice on a few things. First I'll just list what the kit will be cooling;
i7 920 @ 4.0Ghz
MSI 480 GTX @ 850/2100
All enclosed in a Corsair 800D.
The List
* Thermochill 120.3 Triple Radiator
* EK-FC480 GPU Block
* EK Supreme High Flow CPU Block (Nickel/Plexi)
* EK Multioption Res X2 250 Advanced
* 12v Laing DDC-1T +1 Ultra 18W (Swiftech MCP355)
As you can see from my proposed shopping list these are the current components I'm looking at getting. The pump/res/GPU Block I'll be sticking to, but where I'm in need of a little bit are when it comes to the Radiator and CPU block.
I've read great reviews for the EK Supreme, but does it offer the best cooling performance? Are there any other blocks that anybody would recommend? I don't mind spending a little extra if it means the cooling performance is justified for it.
The same basically applies to the Thermochill, I've read in numerous places that the Thermochill is the standard when it comes to comparing 360 Rads, is this still the case? As I've also read that the SR-1 360 is just as great but scales excellently with fan speed. Is it worth the extra £30?
Another thing with the thermochill is that it looks absolutely colossal, and I read somewhere that the fan mounting hole's dont line up properly with the grill at the top of the 800D, is this actually the case?
Finally, you'll see I havent got any tubing or fittings yet. My last venture into WC'ing I just used barbs, but I'm really interested in pimping my kit out (if I'm spending this much already I might as well right?) with the nice bitspower fittings.
However would someone be kind enough to explain to me the difference/usage of "Rotary" fittings as opposed to Compression fittings? Are you supposed to use one or the other? Or in conjunction depending on your layout?
I would really appreciate any input anybody on the forum can give so I can get the most out of my purchase and be sure that I'll have a setup that'll serve me well over the next few years *fingers crossed*.
Thanks in advance
i7 920 @ 4.0Ghz
The List
Thanks in advance
