Watercooling Advice
7 Jul 2005
howdie
I am just about to upgrade my rig from whats in my sig to a q6600 and a 8800gtx on a gigabyte p35 DQ6 board and would like to know if my watercooling kit will cope with the heat or not.
Watercooling wise i have the following to install :
Pa120.2 rad
Swiftech Storm CPU Block
EK 8800gtx full cover block
Swiftech 655 pump
(2 X Maze4 GPU blocks currently on the 7800gtx's)
All running on 1/2" internal tubing
its currently cooling an opteron 170 at 2.8ghz, 2 X 7800gtx's and the northbridge - and although it copes quite well its not ultra cool - so was wondering if the q6600 and 8800gtx will generate as much heat as the current stuff (as the chipset will be cooled passivly on the new board) ?
Oh and the PA120 has 2 Panaflo fans on it (cant remember the model numbers but they are the higher cfm 38mm thick ones).
Advice welcomed as Im hoping to get started on sunday.
Thanks
