Ok I am thinking about taking the plunge soon and thought I would ask for advice.
I think I have the basics put down.
So I would need to buy a CPU Block, VGA Block, pump, reservior, Coolant, radiator, around 10m of tubing?, now what really threw me off is all the fittings and some say G1/4 1/2 3/8 etc. Then theres barbs and clips, I just felt so lost when I thought I would put a mock set in my basket to see and from there I was just blank and I knew I wouldn't be able to get it right without advice first.
Would be greatful if people could explain exactly how I would put a set together and what to look for so I know what size fittings to buy, what style ones and whats the difference between fittings and clips.
