Ok, I know there are lots of these threads, and I'm sorry to ask but I am venturing into watercooling for my existing build. I am quite confident with pc's so am not afraid to go the water route. I am looking just to cool my CPU and Northbridge chipset. My system is as follows and my concern is the case as aI don't know if anyone has water cooled in one :
FRACTAL DESIGN R2 CASE
Asus Rampage Formula Mobo
2 x 5850
The rest is in my spec, the Northbridge runs hot on this board and as I have only just upgraded recently I dont really want to swap out the mobo and cpu.
I think the rad would have to be top mounted on the Fractal case, I could use one drive bay for the resivour, Its just pump placement. Any recommedations would be greatly appreciated. Looking to spend maximum of £200.
I'm looking at the Heatkiller socket 775 Cpu cooler, but not sure on a Rampage formula compatible chipset block. Im running at 3.84ghz at the moment and would like a pump that can go to 4ghz.
If anyone would like to do an example basket for me I would appreciate.
2 x 5850
