watercooling advice
9 May 2010
sheffield
evening all,
later on this year im thinking about water cooling my set up (in sig) also thinking of getting a gtx 580. i wanted your advice, as i have never done this before would i benefit from getting one of the EK Supreme HF 360 water cooling kit, or doing a custom loop? is it difficult? are there any good/recommended sites for me to look at to see how it is done? i got a bit confused looking at all of the different bits i would need :p
GM
this is my thinking, dont suppose you or anyone else could point me in the right direction as to what i would need, im asking now so i can save up for what it will cost lol how is the haf x for water cooling?
Ive got the haf 932 and i think its great.
So do you want to cool your cpu and gpu.?
For high end kit these are my estimate prices. On my phone so can't give you an exact price.
60 per block
60 pump
60-70 rad
15-50 res but they dont make a difference cooling wise it just looks
few quid for barbs and few quid for water.
so your taking 200 for a good kit. But you can easy cool cpu and gpu on a lower budget
sell the 570 and get 580, or the equivalent at the end of year , or sli 570s.
what bits and bob will i need for the loop then? ive seen a lot of this EK? stuff any good?
ek is pretty much what everyone buys 1 there good 2 there cheap (cheaper than some make at same or little less performance)
everything you need is in that link i posted for you
If you want a El block don't buy a nickel plated version copper only since there is QC issues with them.( would link but posting from my phone.
you use predictive text as well ha ha. have to save in ek or it comes out as el.
the chances of getting one are quite slim all my blocks (3) are nickel
