- 2 Aug 2006
- Liverpool
Hi I want to build a custom watercooling loop for my pc but don't know if I'm missing anything, at first I'm just going to cool the cpu and mb but want to add the gpu when I get 1 with a compatible wb, is the following ok
Case Fractual Design Define R6 Tempered Glass Black
Motherboard Block EK-FB GA Z270/Z370 GAMING RGB MONOBLOCK
Radiator EK-COOLSTREAM XE 360
Pump EK-XRES 140 REVO D5 PWM
Connectors EK-ACF FITTING 10/13MM - RED
Tubing Mayhem ULTRA CLEAR WATERCOOLING TUBING (38 - 12) 13/10MM - 1M
Fluid Mayhem X1 BLOOD RED COOLANT 1L
Fans CORSAIR ML120 PRO RGB PREMIUM PWM
Accessories XSPC PSU BRIDGING CONNECTOR
