- 22 Jan 2006
- Lincoln
I'm thinking about setting up a watercooling rig for my 144 opteron, and have had a lot of mixed reccomendations.
One of my friends has had watercooling for ages, and reccomends a Danger Den RBX block, which other people have told me are over the top, so a bit confused. can anyone reccomend one? 1/2" fittings?
I know the radiator and pump i'm going for, some kind of Eheim pump, and a BIX III as they've had good reviews in quite a few places.
Also planning on getting a Lian-Li V2000+ and modding it to fit into there.
thanks for any help, and reccomendations!
). The DD TDX is also a good choice (and RBX with 2 barbs) as is the classic swiftech 6000 block (if you can find someone that still sells them)
