- 17 Jan 2016
- Schlüchtern, Germany
Hello,
i plan on watercooling my PC in the near future and made a component list. As a case im using a Fractal Design Define S.
Parts:
10x EK Water Blocks EK-ACF Fitting 16/10mm G1/4 - white
1x EK Water Blocks EK-XRES 140 DDC 3.2 PWM Elite with pump
2x Magicool G2 Slim Radiator 16 FPI - 360mm
2x PrimoChill PrimoFlex Advanced LRT Tube 16/10 mm - white, 1m
2x Mayhems X1, Clear - 1000ml
1x EK Water Blocks EK-Supremacy MX
1x EK Water Blocks EK-FC R9-290(X) - Acetal+Nickel Rev.2.0
6x Corsair SP120 High Static Pressure fan, weiße LED - 120mm
I know that 2 360 Radiators are overkill for only 1 gpu and cpu. I want more radiator space so i can run the fans at a low rpm or add another gpu later. Are these parts good? Anything i should change?
Thanks in advance,
aceCrasher
Parts:
Thanks in advance,
aceCrasher
